Long overdue upgrade but need advice
Cyber
The time has come to upgrade my system listed in my signature. My goal however is to go with my Stacker case to save funds and to use my Black Ice Extreme II and Alphacool Laing DDC pump.
My new build will consist of the following parts:
Motherboard: ASUS Rampage III Extreme
Processor: i7-930
Memory: Corsair Dominator 6 GB Memory
Power Supply: Antec TPQ-1200 or Corsair HX Series 1000HX
I will be reusing my 36gb raptor drives and upgrading to Windows 7.
I plan on getting two video cards but need to research since I have been out of the loop for a while. Not looking to get the latest and greatest because itvwill change in a few months anyways. I remember paying out of the wahzoo for the 7800gtx ko edition and better cards released very quikly.
My delimea is if I will be able to use the Stacker case for this build. I plan on overclocking the CPU and video cards. I do not know how many watts an overclocked i7-930 or gpus put out. I would guess that the gpus put out considerable more watts than the CPU. Therefore I am wondering if I will need to set up a dual loop.
Will my current black ice extreme II radiator be able to handle dual overclocked video cards?
I was planning on placing the second 120.2 radiator in the front of case.
If I obtain another dual 120 radiator and pump will it be able to handle the overclocked CPU in a seperate loop?
If need be I have a Kingwin K-424 case that I could maybe use as external case to house all the pumps, radiators, and reservoirs but would like to avoid this.
What are your thoughts on this?
I would hate to have to pull the trigger on getting another case since I would like to save the money and use on blocks and radiator. However I was considering corsair obsidian series 800D, Cooler Master ATCS 840. The mountain mods and silverstone TJ07 are great but out of price range at the moment.
I could maybe put a 120.3 rad on top by cutting top of case and moving my current radiator to front of case and placing power supply on bottom.
It depends on what video cards you use and if you plan to overclock them. Because stock power consumption are a lot different from overclocked power consumption. You can find the TDP rating of most cards and cpus, but that is usually the quote for the stock speed.
So let me get this right, you have a double 120mm radiator and you want to add two more radiators to your loop? It all depends on if you want to keep it all inside and what case you get. I think the 800D and the Cosmos S are good waterclocking cases.
There's only a $60 difference between the 800D and the TJ07. That's what the price of a rad? If money is an issue, you can save money by going with Swiftech rads. They are only average performers but they are solid and CHEAP.
Yes I currently have a black ice extremeII rad and was going to dedicate that loop to the CPU.
I was then considering buying another dual 120 radiator that is similar to the above mentioned Black ice extremeII I bought years ago for my current system listed in my sig.
I was planning on dedicating the second rad to my gpu.
My goal is to keep the stacker case since money is tight and was going to go with just one vid.
I know I could mod my case to house a pa120.3 rad or similar on the top of case. Then use my current black ice xtremeII rad for the processor. Advantage to this is I would have a pa 120.3 rad for future use on new case. Rather buy once than have to buy in future.
That way in future when my spousal support drops I can get second vid card and bigger and better case with future potential of more upgrades.
Unfortunately I am stuck trying to use this outdated coolermaster stacker case.
