Long overdue build
eatadonut
Hi all,
I'm finally building the new PC I set aside money for when DDR2 was released. I like to shop for a while. My primary motivation is that my wife just got a new laptop (Lenovo Y530, BTB), and I can't stand the idea of her having a faster computer than me. It hurts.
Sorry for the long post, you can skip the first half if you aren't looking to kill some time.
I do a little bit of everything, with the somewhat notable exception of gaming. I get into gaming for about 20 hours every time a new Need For Speed game comes out, but that's about it. However, I do a bit of coding, a bit of video encoding/rendering, bunches of Photoshop, and some audio recording/processing.
My budget is flexible, but we can call it $600 for the remaining parts. I expect it will deviate some one way or the other.
On a whim, I grabbed the Antec 900 and the 1KW truepower quattro when they were on sale. I'm now thoroughly air-flowed and powered for any build I could afford. I had planned on migrating parts from the dinosaur I nurtured for the last 6 years or so, but an electrical storm killed every single part (with the exception of one HD) in one blow. So, I need everything else.
I enjoy overclocking, and I'm in the fortunate situation where my computer is no longer mission-critical to my work or school, so I will certainly be doing a moderate overclock - more for fun than for real usefulness, and I don't have any delusions of breaking records, so it'll be good solid air-cooling for me.
I've got an old 19" 1280x1024 LCD that I love, and it will be my primary monitor for at least the next 9 months. I plan on upgrading to at least a 24" after that, but not before unless some insane deal pops up.
I haven't decided if I want to grab a new HDD right now, I've got my eye on the 640AAKS. I still have 920GB of assorted slower drives (I believe there's a 320GB 7200.10 that is my fastest) - how much benefit would I see from the 640AAKS? I do a lot of photography/photoshop stuff, and I do hate waiting for my enormous folders to load.
So here's my thoughts:
CPU: Q6600
Memory: G.Skill 4GB DDR2 800 (2x2) kit (x2, for a total of 8GB)
http://www.newegg.com/Product/Produ...231122&cm_sp=DailyDeal-_-20-231-122-_-Product
Mobo: Gigabyte GA-EP45-UD3R
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
GPU: A little shaky - I was thinking either the GTX260 or one of the 4850s?
EDIT: I forgot to include a HSF - my laptop battery is dying rapidly, but last time I looked, the TRUE was in vogue. I'll be back in the morning to check on that!
The things I'm most worried about are as follows:
1) The memory is rated at a FSB of 400 - that's way above a reasonable 1:1 overclock on the Q6600, right? Am I having a major brain fart here? It seems like 9x333 is pretty popular, and that's way under the limit on that kit. If not, I have no problem upgrading to the G.Skill 1000 for a few bucks more a kit, but there's no reason to toss money away.
2) I'm always unsure about my mobo choice. I think it's just a mental block. But that one gets good reviews, and I like the color.
3) Really, I think it's a function of cost/performance, and software on the GPU. I don't do a ton of gaming, and right now running at 1280x1024 I realize I'm pretty much bush league. Are there any major issues these days with either nVidia or ATI software? I remember back in the day it was hell getting one of them to work, and then 3 years later I couldn't get the other to work, but I'd hope by now they had all the hydravision/nTune/random bloatware crap settled.
Also, I have a strange fetish for this XFX GTX280, and I don't know why. My brain tells me that it's WAY too much GPU for me, but my ego says otherwise.
http://accessories.us.dell.com/sna/...6&cs=19&c=us&l=en&dgc=SS&cid=30322&lid=680413
Other than that, there's just optical drives and hard drives - if I get a new HDD, it'll most likely be the 640AAKS, and unless there's one optical drive out there that is leaps and bounds better than the rest, I'll grab something in the $20-30 range that gets consistently good reviews.
Since you don't play any graphic intense games or play games as much, a Radeon HD 4850 would be more suitable. But, if you looking at a 24" monitor , then get the Geforce GTX 260 (216)
BTW, that XFX Geforce GTX 280 is waaay too much GPU for you if you don't play games like COD, Crysis, Stalker, FO3, FC2 etc. No point of getting that GTX 280 card. Also, a Radeon HD 4850 will be very good already for your 19" 1280 x 1024 res display.
A more ideal thing to do if I was in your shoes
1. Get a Quad Q6600 CPU and O/C that to 3.4-3.6ghz
2. Don't spend too much money on a video card if you are not a serious gamer playing graphic intensive games. A Radeon HD 4850 or even less would be sufficient for you even for a 24".
3. Get a very good 24" Non TN display for your Photo editing since you mention you do alot photoshop stuff. You need a solid LCD that can give you a good display of your photos. The cheaper TN panel 24" for $400 and under suffer from color shifting due to poor view angles and does not display the full 16.7 million colors. Look at these monitors if you get a 24" display
HP LP2475w 24" S-IPS Panel
BenQ FP241VW 24" S-PVA Panel
4. Definitely get the WD 6400AAKS 640gig drive for its performance and value. Worth it!
Okay, after a little more reading and shopping, this looks like it could be the build - any problems? Some of these things aren't in stock at newegg, so I'll either wait, or look elsewhere.
Thanks for the links to those monitors, HG - that Benq is a good-lookin' piece.
CPU: Q6600 $180
MOBO: gigabyte ud3r $120
RAM: 8GB g.skill $90
HDD: 6400AAKS $75
GPU: 4850 $150
HSF: xigmatek 120mm rifle $36 + ~$10 for fan +~$10 for mounting bracket
Total:
$671
The xigmatek model I want is the 1283, right? Which mounting bracket do I need for that? Also, there won't be a problem with that fitting on my mobo, or in my antec 900, right?
Thanks [H]. I'm sure you guys know how much you help out the newbs and lurkers like myself, but let me throw my appreciation at you too.
You are looking for the Xigmatech ACK-I7751 which is also out of stock at Newegg right now. I don't think you'll have any problem fitting that heatsink on the UD3R inside your Antec 900.
Also, don't forget about a 64-bit OS for all that RAM!
Ahh, thanks. Hopefully that'll come back in stock in a reasonable timeframe.
Yup - the wife has a hookup for all the free vista enterprise I could need, as long as I don't need more than 2 :D
