What would be the best way to network a webcam so that i can use it from ~500ft away? I know cat-5 is shit after 100ft is it? And wireless might be too expensive for that kind of range .. I need a cheap solution, what do you guys think?
As for wireless, that depends. Is it 500ft of open space, or are there walls in the way of getting a signal? If it's open area, then a wifi enabled camera would do the trick.
It's not open space, there are buildings obstructing the path. Would it be possible to put a switch in the middle of two 100m wires and still get 100% "signal"?
I believe it should work... a switch should act like a repeater (as hubs also do), but I might be wrong, though a switch is not the same as a hub, I'm speaking on the sake of a relay of power. However distance is determined by diminishing signal due to a drop in voltage so a powered switch should extend your distance.
You'll have no issues with signal degradation over 500ft....You should be good out to about 2km. If you watch eBay for a few days, you can usually snag some killer deals on the actual fiber itself too.
