First, here's some maybe relevant details about the build with the problem:
- Mobo: Asus P5E-VM HDMI (the cable and ports are SATA 3gb/s, but the SSD is 6gb/s)
- 4 sticks of 2GB ddr2 ram
- SATA DVD drive
- SATA mechanical hdd (disconnected)
I put a new SSD (which I've verified to work flawlessly in a new build) into the old build described above. I permanently disconnected the old mechanical hdd, then did a fresh install of Windows7. However, there's a problem:
* It takes a very long time to reach the Windows login screen. POSTing is quick (about 4 sec), but right after the POST screen, I get a black screen with a single blinking cursor at the top right. This lasts for about 35 seconds, the cursor moves down a space for a second, and then the Windows 7 splash screen finally appears.
* Also, with SSD's, this splash screen should usually finish before the 4 colorful "window panes" connect. However, in my case, the splash screen lasts for several seconds past the moment they connect. This time frame is almost as long as when this old build was booting off the mechanical hard drive.
After the splash screen, everything else loads normally.
So what I tried is take the SATA cables for the DVD drive and old mechanical hdd and switch it to the SSD one by one, in case any of them were higher priority ports on the mobo. But nothing changed. I checked and AHCI mode is also enabled.
Any help would be appreciated. I put the SSD into my old build to speed things up, but it's frustrating how everything seems slower than before with the mechanical hdd. Thanks!
- SATA DVD drive
