LOL omg Alienware w/ SLI now
Not that I endorse buying a premade DIY, but the ALX systems are watercooled, come with a different sort of warranty and a briefcase full of crap.
And since when did a non-SLI system compete with an SLI system?
harddrive performance, processor performance? as far as video performance, yes sli is better but please tell me a current game that other cards cannot handle
Theres a difference between handling a game, and out performing in a game.
My notebook with a 9200 can "handle" Doom 3, but I'm pretty sure a mobile 9800 can out perform it.
Its all about the e-dick, thats all its ever been about. Thats why nvidia and ati exist at the levels they exist at.
The ALX gives you alot of stuff. It's got badass performance. But it is overpriced. You could assuming all the parts you needed were available, build that yourself for less.
You think $5400 is bad, try configuring one of those and maxing out the options. (Just hardware) I got to $13.k
The outsides of the new AW cases are all that are different, for those who are wondering, the actual panel and all look pretty much the same as the dragons. The ALX, looks as if it uses a Koolance or similar system.
$37,170.00 for everything. Wow, that's expensive :rolleyes:
Panel?
The dragons were steel (and freaking heavy), the new cases (predators) are plastic panels on the outside. The insides have also been updated, one example is a new hard drive cage design.
The alx case uses a chassis that was co-designed by koolance and alienware; and is only used with the ALX. Uses toolless bays and 1/4" tubing.
1/4" tubing? What kinda crap is that....I would expect 1/2" tubing for that price.
Its all koolance has ever used in their systems. 1/4 is easier to maintain, less water/weight, etc.
Alienware isn't going to be OCing, in fact that voids the warranty, they want quiet and cool; 1/4 delivers that.
