Logitech Z Cinema question
Le037
Are these speakers any good? They connect through usb, so that means I don't need to buy a good sound card?
It means you don't need a sound card, although there is an auxiliary input if you felt the need. I assume the DAC on the Z-Cinema would be sufficient that there would be a negligible compared to a high end sound card.
