Logitech z-560
latief75
i've had the Logitech z-560 system for two years now. i have no use for them on my computer any more, so i want to hook them up to my home dvd player. is this do-able ?
Can you tell me how ? i don't see any connecters that match. the z-560 has only a wire going out to the sound card. no other types of plugs or connectors.
thanks
i think i'm going to go with it, but then i'll need an RCA cable splitter ...correct?
also, since it is a 5.1 adapter, do you anticipate any probelms with a 4.1 system ?
thanks,
i managed to get the plug, it worked,
i'm not sure, what does the z-560 system qualify as ....? is it a dolby surround system ? a dts surround system ? how can i setup the DVD device to work properly
i'm not expert on this so please let me know, i want to set it up correctly .........
thank you ..
