Logitech z-5500 question
Spike
Just got the logitech z-5500's and when i opened th box it says keep at least 2 feet away from other electronics ie tv's pc's and monitors. does anyone know if the magnetic field would mess up my modem? and also anyone know if it would interfear with the coax cable for a tv. Responses apprecieated, thx 4 your time.
edit: New question was testing the speakers, so i decided to play red hot chilly peppers Otherside and for some reason all 5 satelite speakers cut out you can hear a little from the center. It isnt my sound card, i have the new x-fi by creative. any suggestions on the possible prob? works with other songs. Would an optical cable help this prob?
not for me... it's right next to my modem... and my other set.. z-680's are right under my tv and ps2 and what not.. fine for like 4ever.. BUT keeping the sub next to the monitor would mess up the image though..
I've acidentally laid memory sticks on it and stuff and they were fine. Probably only relevant if the sub is loud? Im not quite sure, would be intresting to find out though.
Nvm on the second question i had accidentally set it into stereo 2 mode fixed now
