Logitech wireless keyboard question
wesmaster
i already have a MX700 mouse but i was wanting to pickup a wireless keyboard but all the ones on newegg are combos with keyboard and mouse. does anyone know how much a logitech wireless keyboard costs and where to pick one up?
To tell you the truth I've never really seen the Elite Keyboard in wireless form by itself. I picked up the MX Duo from work about 5 months ago and I couldn't be happier. :cool:
The only stand alone logitech keyboard I've seen is the Logitech cordless access (not the elite keyboard), however I haven't been able to find it anywhere lately.
Everything I see now a days are only wireless combos (from Logitech or MS), so you might have to poke around some stores. But you might end up having to buy it in a combo form if you want a wireless these days.
I just got the MX duo, and after realizing my mouse pad made the mx700 jump around, the set now rocks.
I ended up going back to a mouse pad just 'cus I liked the "feel" of it. Since my pad doesn't really impede on my "freedom of movement" I'd much rather use what feels better.....especially with the amount of time I sit here. ;)
well i guess i can always upgrade to a duo with the mx900 and sell my mx700. is the mx900 that much better than the 700 to warrent an "upgrade"?
It's bluetooth, so you're basically just gaining from that. If the ability to use your mouse from around a corner doesn't interest you then maybe it isn't worth it. ;) :p
