Jellyfishpudding
- Oct 12, 2006
Lately I've been enjoying the silence of mice and landed Logitech's new M330, whose build is identical to the Triathlon. Its form is close enough to perfect for my grip, but its lag issues are concerning. Unless you think otherwise, I'm chalking it up to a poor sensor. Either that of the hard Corsair mouse pad I'm using isn't being registered effectively. My little BlueTrack Microsoft mouse is as smooth as silk, so there do not seem to be system issues hogging its ability to perform.
What do you think? Get a replacement mouse? I'm seeing lag when using it on the slick wood grain desktop finish, so I'm hesitant to buy a new pad. I could go with the Triathlon, but I fear it's using the same sensor (its the same DPI). Any recommendations for things to try or do would be greatly appreciated.
Thanks!
Eddie
Thanks!
Eddie
