Logitech Rumble Pad 2
|Leviathan|
hello all
my query is that i got a logitech rumblepad 2 [wired version], i use this mainly while playing pro evolutio soccer 5
is there a way i can turn vibration feedback on while playing this game? is it from my gamepad / settings or the game doesnt support it?
thanks in advance
There is a button the gamepad itself.
In the center, there are 4 buttons, right? I believe it's the bottom right one. Turn it on and it should vibrate. Short vibration = vibration off; long vibration = vibration on.
lol yeah i know bout that but nway during gameplay no vibration at all lol, i configured from the logitech profiler that the vibration is on an 150% feedback *grin* but no positive results =/
I hate to tell you, but the support for the rumble feature would have had to be supported by the game, and a lot of games currently do not.
I know that the Logitech software can help with some, so I would try that to see if it hs a game profile made for it, otherwise I don't think there is anyway to help you.
Heck even Madden 06 does not have rumble support on the Rumblepad 2
