Logitech MX700
133
I got one from a friend, just the mouse and base.
I just put in some new NiMh rechargeable batteries
light is blinking after about 5mins of use, so i put it on the charger...
How can i tell if its charging or just sitting there?
is there a sign to see if its charging or what
You will see the Red LED off the back turn off, and a green LED off the front/top of the mouse blink....When it stops blinking, it is fully charged..
mine just keeps blinking red
have never seen it green
Sometimes the mouse isnt seated correctly to make contact. Try to clean the contacts on both the mouse and chargingstation first, make sure the powersupply is connected properly and then place it in the charger. I f the red light doesnt go out en the green comes on, take it out and reseat it again untill it does....
Works for me..... ;)
piesang said:
Did you plug the charger in? It plugs into a wall socket seperately.
that would be it...i don't have the plug that came with it so does anyone know what kind i need
bump
anyone know what power connector i need to get for this charger ?
I would contact Logitech about getting the adapter.
It is an AC adapter with an output of 5.8V at 1A.
