Logitech MX1000...
acetic
Is the mouse worth getting? I've read reviews and stuff, and from what I've read I'm going to buy it in the morning...
Can anyone give me a reason NOT to buy it? It will be an upgrade from a Microsoft Intellimouse w/Ball. Is there any major glitches that i should not buy this mouse because of, or is it all good?
And a question for owners: Can it be used in the LEFT hand? I broke my right hand, and my cast is all funky, so I can't mouse for long, and I wish to use my left for some mousing.
Thanks in Advance.
(and sorry for slow replys after this... Typing = slower than normal :))
I have it, wonderful mouse. The mouse itself is shaped for right-handed people so using lefty wont be easy,
I am currently using this mouse right as we speak and I must say it is the best mouse I have ever used. However regarding your "can it be used with your left hand" question, unfortunately it would it incredibly akward to use that way. A good mouse for you would be an other style Microsoft mouse with the page forward/back buttons on each side.
Sejin
Thanks alot :D
Bah, cast is only on for 3 weeks, I can live with a little awkwardness for then :D
Well if you are not a progamer and big weight is not a problem for you it will be perfect for you!
