Logitech MX Revolution replacement
ghostchild
Are there any mouses out that are just as good as the MX Rev for multitasking, buttons and scrolls, and charging? The new Logitech ones don't use the cradle anymore and the charging methods suckkkkkk :(
I think the new charging method is a huge step forward. If your using a cradle you can't use your mouse. With the new Logitech Performance MX when your battery runs low you just plug in the usb cable and continue using your mouse as if it were wired.
I just have the habit of leaving it in the cradle when I don't use it. And the fact that the performance doesnt have the side scroll.
I'll be honest, I dont think I have ever found a use for the side scroll, the document flip in win7 is cool but not necessary...
My use for the side scroll on the revolution (using the UberOptions): volume control, with the button press to mute. Very nice since I don't have a multimedia keyboard.
I've also been looking for an upgrade to the MX Revolution, but the MX Performance just didn't cut it. I've been eying Cyborg RAT 9, which is considered a gaming mouse, although I don't game much. I just like the looks of number of buttons, side scroll wheel, and the programmability. I just hope it's sturdy.
the side scroll is so useful for apps like photoshop and firefox well at least for me.
side scroll was my zoom function, which is essential for a HTPC.
search was re-programmed to document flip.
I had the MX 1000 which was a very nice mouse. It had a cradle but it was cheap and light and moved around on my desktop so much, I had to velcro it down. I don't like cradles now.
Bought the MX Performance and disliked it. Odd shape for my hand. The charging solution was to replace the cradle with a micro USB cable that allowed the mouse to be used while it was charging. I disliked having an extra cable on my desk and the mouse still communicated with the PC by wireless even while the USB cable was plugged into the mouse on one side and the computer on the other. If logitech designed it to use the USB while plugged in, this would have been a great gaming feature. But No. Fumble.
I bought an older model MX 1100 on the Logitech site for $40 ("dented box" actually means opened box but everything was new) and even thought it doesn't feel as high quality as the Performance MX, it is a much better mouse IMO. It has a more subtle look that the Performance with all that tacky chrome-like trim. It has side scrolling and doesn't recharge but at the rate I'm using battery juice, it should last about 3-4 months with A LOT of gaming use. My Performance needed recharging about once a week and didn't give a warning (an LED turns red for a moment but is easy to miss). And no more cradle or extra cables around my desk. I thought I would use a lot of batteries but I'm still using my first set of AA. And it will even work with one AA in a pinch.
Link
Well after about two years the MX Revolution had the left button switch fail. Called Logitech support and they sent a new Performance MX mouse. They were very quick to respond and to send the new mouse. Was pretty excited to get a new mouse with new features. Instead of new features they removed some. I used the Performance for about a month and then finally had enough and bought a MX Revolution off of the Bay NIB for a little over $50. It arrived today and it's good to have SmartShift and the thumb wheel back. Also the button just behind the top wheel on the Performance is just a on/off switch to turn hyper-scrolling on or off that cannot be programmed. The Revolution also feels more solid.
The only thing the Performance brought to the table was the ability to charge and still use the mouse by plugging in a micro usb cable into the front of the mouse. The second thing is the bottom thumb button. I find it's a good place to have a button which I use to increase or decrease the DPI sensitivity. Gamers might not like the position of it since accidental activation of this button will probably occur during the heat of battle.
Hopefully Logitech learns from this experience and SmartShift as well as some of the other features of the MX Revolution make a return in a future mouse.
Describe how your left button failed...mine just started random intermittent double-clicking last night and I've had mine about two years...is it really still under warranty?
The exact same thing happened to me, the left mouse button double-clicked on its own. Luckily I still had my amazon receipt saved in my gmail, so logitech support replaced it with a brand new performance MX.
The new charging method is a huge step forward, IMO. I do miss smartshift.
My MX1000 started to do the double click thing as well. I paid $20 to upgrade to the Performance MX, vs getting the MX1100 for free. I wasn't able to hold an MX1100 in person so I didn't really want to get one blind. Best Buy has the Performance MX so I went there and felt it before deciding to upgrade my RMA.
I've been using the new mouse for about 6 weeks now and am pretty fond of it.
Weird. I just sent in an RMA to Logitech because my middle mouse button no longer worked. Mine was a combo with the MX5500 Revolution keyboard, so I hope they send me that and not some POS new model replacement.
I'm planning on buying the performance mx of logitech, is it way better than the anywhere mouse mx or just because of the additional buttons and charging method?
