Logitech MX Revolution question (for owners)
ryansebiz
I just bought the MX Revolution at Staples (for $88 w/ tax).
The tilt wheel is loud! I give it a good whirl and it starts clicking like a grasshopper on speed.
I was disapointed because the one they had on display had a silent scroll wheel.
For other MXR owners, does your scroll wheel make any noise or is it silent?
Should I just spray some WD-40 in there?
If it was a walk in purchase from a B&M, then I would just go back and ask for a replacement.
It's dead silent for me. You probably have a slight defect in there. The little metal clicker for click-to-click mode probably isn't getting completely out of the way when you shift over to free-scroll. It should be able to spin free for several seconds.
And this may sound silly, but you know I have to ask, are you sure you're not in click-to-click when you hear these sounds?
WD-40 in a mouse.........You joking right! To put it in free wheel you need to press down.
Mac
