The Chosen One
- Feb 4, 2001
Hey guys, i was in the middle of typing something last night when all of a sudden, mid sentence, the kb just stopped responding.
I tried pushing the reconnect buttons on the KB and on the receiver to no avail. I then restarted to see if it would fix it, still nothing.
So i figured that after 18months, the batteries must have finally gone flat (even though the battery indicator still said "fair"). So i replaced the batteries and restarted, and it started working again......almost.
After i few minutes, i tried to use the hotkeys to pause a song in Winamp, and instead it turned the volume up a notch...then i tried pushing the F-Lock button, to see if it was that, and nothing happened. The Email button Mutes the sound.... but the actual mute button doesnt work.
Its all gone completely haywire getting the signals mixed up.
Ive tried uninstalling and reinstalling the I-Touch and Mouseware utilities, but nothing seems to make a difference. I dont think its that, as even when i have nothing installed, the Pause/Play button still turns the volume up a notch, so it shoudlnt be software related.
Funnilly enough, at about the same time Firefox conveniently deleted all my bookmarked webpages.
Oh also, i put the old batteries back in, and they wernt flat after all, but the kb is still doing the same thing
Anyone got any ideas to fix this, its driving me crazy
P.S. and i just noticed that teh F-Lock light is staying on on the receiver.
