Logitech mouse and KVM switch fubar's the scroll wheel
Spudsdude
Using a Belkin 2 port KVM (keyboard, video, monitor) switch.
Mouse is using the USB to PS2 adapter and plugged into the KVM.
On initial boot the mouse functions fine, when i switch to the other computer and back the scroll wheel causes all sorts of oddness. (like refreshing the screen when scrolling via the scroll wheel)
Anyone have a logitech mouse and a KVM that doesn't have this problem? if so what KVM are ya using.
Thanks!
Spuds
I'm also using a Belkin KVM switch and I'm using a Logitech Mouseman Wheel opitical and I'm using the USB to PS2 converter with no problems. The only problem I had was with my Microsoft Internet keyboard. It wouldn't allow me to switch between computers, so I traded it for my wife's logitech keyboard and it works fine.
i have the same belkin switch only with an ms explorer mouse. only problems i have is sometimes it doesnt wanna work when i switch between comps, unplugging the mouse and plugging it back in always fixes the problem. (which rarely occurs)
...i don't find it as much of an annoyance cause i only switch to my other computer maybe 5 times a week max... if you switch comps often, might get really annoying. have you tried powering your KVM switch maybe? that seams to fix problems in everything...
I'm using the same microsoft keyboard, i'll try swapping that one out.
As for powering the KVM, good idea =) I'll give that a try as well.
I switch between the two machines all the time, one's for work the others for fun.
Thanks for the ideas!
Spuds
