Logitech Harmony 880 Advanced Universal Remote Control $99
mo_money
http://www.buydig.com/shop/product.aspx?sku=LTHR800UR
Add it to your cart and the price drops to $99 with free shipping
Limit one per customer.
The Harmony 880 Advanced Universal Remote puts you in control of your entire audio-video system with just one button. It's home entertainment the way it should be-simple.
Optimized for complicated HDTV and PVR systems, the Harmony 880 helps you tame tough configurations like switching your television between video aspect ratios depending on the program source. The interactive color display lets you quickly choose a 16:9 ratio for movies and HDTV, or a standard 4:3 ratio for basic television programming.
Award-winning Logitech Industrial Design
High-end systems deserve a high-end remote. Designed with brushed chrome and charcoal accents, a color LCD display and a low-profile recharging station, the Harmony 880 Remote will match your most advanced audio-video components perfectly.
Logitech has won a total of eight Industrial Design Excellence Awards (IDEA) in the past two years, including five of Japan's prestigious 2004 Good Design Awards. This experience helped us design the Harmony 880. Featuring a comfort grip shape and a centered directional pad, it fits easily in your hand and naturally guides you to the most frequently used controls. Even the buttons are sculpted, to help you locate them by feel not sight.
Patented Smart State Technology
Smart State Technology allows the Harmony remote to completely control an entertainment system by knowing how to control each separate component while tracking the current state of up to 15 devices simultaneously.
Functionality:
1. Easy to set up/Easy to Use:
Just connect your Harmony remote to your computer and the Web wizard walks you step-by-step through a simple set up. Enter the model numbers of your components, then answer a few easy questions about how you "Watch TV" or "Watch a DVD." Harmony lets you control even the most complex system without the hassle of programming complicated macros.The Harmony Remote is the world's only remote with Smart State Technology. Simply press an Activity button, such as "Watch TV" or "Listen to Music," and your Harmony Remote automatically sets up each of the devices required for that activity.
2. Easy to get help:
With the Harmony remote, you don't have to know anything about your entertainment system to operate it. No sound? No picture? No problem! There's even a handy "HELP" button to guide you through simple troubleshooting and get you back in control.
3. Never out of date:
The Harmony device database includes 5,000+ manufacturers and 175,000+ devices, everything from HDTVs to DVRs, VCRs to lighting controls. It's constantly updated with new components and fine-tuned settings, so your remote will never be out-of-date
Key Features:
Color display:
Why settle for another boring remote? The Harmony 880's color LCD is both functional and stylish, with user-customizable backgrounds, button icons and text.
-Ample space for up to eight custom activities or controls
-On-screen battery level indicator shows you charge status.
Recharging station:
Never replace batteries again. The Harmony 880 includes a sleek docking station that keeps the remote fully charged. Your family will always know where to put the remote-and you'll always know where to find it!
-Lithium-ion battery provides up to a one-week charge under normal use.
-The horizontal docking station allows remote to be used while charging.
System Requirements:
PC:
Microsoft Windows 98SE, 2000, Me or XP
USB port
CD-ROM drive
Internet access
MAC:
Macintosh OS X 10.2 or later
USB port
CD-ROM drive
Internet access
More Product Information for the Logitech Harmony 880 Advanced Universal Remote
The Harmony 880 Advanced Universal Remote puts you in control of your entire audio-video system with just one button. It�s home entertainment the way it should be simple.
Specifications
General Information
Manufacturer Logitech
Manufacturer Part Number 966187-0403
Manufacturer Website Address www.logitech.com
Brand Name Logitech
Product Line Harmony
Product Name Harmony 880 Advanced Universal Remote
Product Type Universal Remote
Technical Information
Compatible Devices HDTV
Compatible Devices PVR (Personal Video Recorder)
Features LCD
Display & Graphics
Display Screen LCD - Display
Battery Information
Batteries Lithium Ion (Li-Ion)
Battery Life 1 Week
Miscellaneous
Package Contents
Recharging station
AC adapter
USB cable
Lithium-ion battery
Installation CD
Installation guide
Additional Information
Easy to set-up
System Requirements
PC:
Windows 98
Windows 2000
Windows Me
Windows XP
USB port
CD-ROM drive
Internet access
Mac:
OS X or later
USB port
CD-ROM drive
Internet access
Certifications & Standards
FCC Part 15 Class B
Warranty
Standard Warranty 1 Year Limited
Parts Warranty/Labor 1 Year
yeah, I have this remote and love it. I was thinking that I'd go with the RF model after using this and I don't think I will. The IR on this thing is powerful and gets my TV from many different angles.
I don't really like mine. I would probably even prefer a cheaper one like the logitech xbox360 that runs on special from time to time.
It's the buttons, especially the numbers. There isn't a spot carved out of the plastic for each of the buttons individually. Rather they all sit on some kind of honeycomb membrane rather flimsily and loose, making the middle ones too spongy. These same middle ones don't always seem to fire even when you get the tactile feedback and "click." Press the 5 harder because it didn't register you could accidentally get the 8 since there is no separation. Maybe I just have fat fingers, but the design is to blame also.
I bought this one on amazon for 99$ last march.
New its only 106 bucks from amazon at the moment too, so not sure how hot a deal.
not that hot, i got mine for 75 amir 6 months ago
delay in this remote is annoying btw, seems like most people are not sensitive to it, isure am
You can program the delay however you want. I love mine because it actually does what it says. First remote I've had that does.
oh i know, trust me Ive messed with the remotes settings MANY times. still a slight delay, like I said not everyone is sensitive to a ~10-20ms delay
I need to mess with it some more one of these nights, when I am on another source, say my Xbox360, and I want to watch TV, it doesn't scroll through my TV's sources to get to HDMI.
Plus I need to mess with the delay settings. Mine are at Default and bug the hell out of me (I've been dealing with it like that for a month)
Had mine for like a year, I think it was $80 for the refurb on amazon about a year ago and new for this price from dell about a year ago.
So I guess it might still be a deal if you figure in inflation since then :p
i have a 680 and its absolutely fantastic. but on the other hand, that 550 that keeps going on sale and everyone raves about is honestly not as good. the biggest problem with the 550 is the 'two clicks to do anything'. most harmonies have dedicated buttons or menus for activities, while the 550 has an activity button you have to push first, then find what activity you want. doesnt seem like a big deal, but this is an everyday nuisance. also, i too noticed a terribly long lag between its commands... im not sure how much of this delay you can take out on the 550 though, i just know out of the box it is slow as dog crap compared to the 680.
I also found that the speeds also change depending on the equipment being controlled. Some devices don't work with less delay. I had to play with delays to get my one button" activity features to work, but it really wasn't a problem. Like some people, some equipment is slow :p
