Hi,
I'm very demanding gamer when it comes to mouses, I've tried many of them and seems like the best for me is logitech g9 / g9x -> the shape is absolutely perfect BUT...
This is laser mouse, the lift off distance is high - I don't like it. So I tried to lower it:
1. I looked all over the internet for some firmware reducing lift off distance - havent found any
2. I put scotch tape under the mouse to cover part of the sensor -> didnt help much so I give up with scotch tape ideas...
3. I bought new mouse skatez and sticked them on the default ones, so the sensor is now higher then on default skatez. It helped a bit but new problem occured -> sensor loses traction during very fast moves. Ok so I changed mousepad -> it helped (still loses traction but on extremely fast moves which I dont do in gaming).
The lift off distance is still to high for me
I bought another mouse skatez but with 3 sets of skatez sensor started to lose traction very easily :/ so I only use 2 sets now.
I'm still looking for a way to fix this lift off distance, any ideas?
