Would be nice if someone had the blue's to comment lol
BTW people might want to be aware of this
http://logitech.pissedconsumer.com/...ized-reseller-from-amazon-20140929539962.html
Apparently somehow Logitech found some material to use on these that sucks, never had a key break on a keyboard before lol.
Chizow I felt the same way. I tried the Brown 710 @best buy buy didn't like how it felt. It really felt just like my decade old keyboard..did you order the blue's 710 yet? Can you post a review here once you do get it?
chiz have you got the blue log yet?
How do the blues feel compared to the brown? Is it significantly better? Bit afraid to keep mine now that you said they are really loud lol..Mine just came in today but wont be able to test until tom..
Just an FYI from a G710+ owner, I do not recommend the keyboard overall. It is not bad, but the keys have quickly worn off the lettering. The palm rest has developed a smoothed sheen where my palm rests and it simply cannot be cleaned off. The keys are glossy and seem to absorb the oils from my fingers at a quick rate.
I regret not waiting for a Corsair K70 (yes, even with its flaws) or a higher quality mechanical board. A friend of mine gave me his old Corsair K70 in black and I enjoy this board a lot more. aesthetically it is much more pleasing.
Overall the color scheme and quality are just not awesome on the G710+ in my opinion. I think a matte wrist wrest would do wonders with some type of change to the key caps as well. Outside of that the switches and functionality of the keyboard was decent.
How loud is the K70 (which switch-type?) compared to the G710+ ?
And what are the K70's flaws? The back-lighting failures on the non-RGB models?
My friend has the k70 (mx browns, red backlight) and he really likes it.
I like that the keys are not embedded in a trough, instead they are mounted on top of a flat surface so debris won't build up under there. Cleaning becomes easy.
It'd be nice if they'd come out with a "K75" with:
- mx browns for me + O-ring dampeners if it's too loud.
- A column of 5 macro keys to the left, and maybe a few up-top like the g710+
- 1 or 2 macro keys below the spacebar, for the left thumb. Some keyboards have this.
- A full set of media / internet convenience keys
- Simple low-bloat software (Razer's LED control is much simpler, I'm told)
- $130 or less. Lose the RGB if that's what it takes...
dsmwookie what keyboard would you recommend that has programmable keys & media keys that is mechanical?
Why do you even care if the lettering has worn off? No one looks down at the keyboard when they type these days do they? On my Sidewinder X4, the keys all wore off in pretty short order but honestly I didn't give a crap.
Found your answer, I think. Apparently one of the links has the 32 bit and 64 bit backwords.
http://forums.logitech.com/t5/G-series-Gaming-Mice/Windows-64-bit-LGS-Software-Incorrectly-Linked-at-Logitech/td-p/1345228
If you don't want to click and read, here is the direct link to the 64 bit version from support:
ftp://ftp.logitech.com/pub/techsupport/gaming/LGS_8.57.145_x86_Logitech.exe
Does anyone know how to setup the programmable keys?
I've already sent mine back once. Have had both of my CTRL keys break twice now. The second time I didn't bother sending it back because instead of just sending me replacement key caps, they make me send in the entire keyboard.
Instead I just bought replacement caps from http://www.maxkeyboard.com/
The CTRL keys are 1.5, I bought these, they work wonderfully: http://www.maxkeyboard.com/r1-1x1.5-cherry-mx-portal-keycap-set.html
You can also buy an entire replacement set if you want. And I do have to say, the quality of these caps are ridiculously better than Logitech's. I don't ever see them breaking.
Also, most everything is 50% off from here right now for BF sales.
That being said, everything about the keyboard besides the caps I absolutely love.
Also, it's on sale for $90 at Amazon right now: http://slickdeals.net/f/7448030-logitech-g710-mechanical-gaming-keyboard-90-free-shipping
It's $89.99 on BestBuy actual too. If I didn't just pick up a stack (9x) of G15 v1s in excellent condition for $8 ea this evening, I would definitely get one.
Why not? When I'm working, I want everyone to know dammit!
<--- Using an IBM Model M13 at work
