Digital Oxide
- Sep 2, 2005
I've seen it at NCIX and a couple other places, it's cordless. I've been thinking about buying it though. Anyone know if it is any good for gaming?
YES. Essentially, its the wireless G5. Heres the best part: No docking station, When you get the mouse you get 2 RC Style batteries, chage one up, then pop it in your mouse then pop the other in your charger. battery starts running low? Oh well you have a fully charged battery ready to go! AFIK: The battries slip in the same slot as the G5 and replace the weight set you have in the G5, so its a nice easy quick battery swap.Digital Oxide said:I've seen it at NCIX and a couple other places, it's cordless. I've been thinking about buying it though. Anyone know if it is any good for gaming?
