Logitech G5 Mouse Game Bind Problem
Syclone
I've had a G5 for quite awhile, and I can't seem to get the thumb buttons to work as other mice have worked.
My problem is that I want the two thumb buttons to work like the left/right/middle mouse buttons do. If I bind something to one of those buttons, it works to hold the key press until I release it. So if I bind crouch to mouse 2, it keeps a game in crouch until I release. However, if I bind crouch to either of the thumb buttons, it does not hold the crouched state. It crouches for a half second and comes right back up even if I hold the key down.
I have tried changing the function of these two keys in Set Point to other keys to see if that might help (I have them set for normal windows as forward and back for the browser). Still does the same thing.
I'm running Vista 64.
If I can't figure this out, I'm going to have to go mouse shopping as it's driving me crazy.
Just put the latest drivers on from last month and they may have fixed it. More experimenting will be done.
This has been a long standing issue for me in Vista 64. Glad they fixed it.
Scratch that, it doesn't fix it. I can sometimes get it to work, then it will revert to being broken. Sometimes this is related to going from windowed to full screen.
