That would explain it, my keys have a slight texture, can't really feel it but you can see it in the right light.tikicult said:What are your keys like? The first run of keyboards were missing a coat of clear coat to protect the keys. My G15 had smooth keys, while the one my brother bought later had textured keys. The smooth key ones are the ones being worn down.
Met-AL said:No go on the replacement for me. They wanted me to send my old one to them first and then they would send me a new one. I didn't want to go two weeks without a keyboard over 3 keys and if I had to go buy a temp keyboard, I may as well go buy another one and take this one to work for using in my office there. I asked if they could just send me the three keys and I could change them myself. He said they weren't able to do that.
He also told me that the early manufactured keyboards are having the problem with the "fading" keys and the later manufactured ones do not have this problem.
I can't blame them, probably alot of people scamming them over this so it is no suprise they want the old one back first.
tikicult said:Wow, I seem to be the exception. I think I just got lucky then.![]()
kick said:Hmm... backlit keyboards... how 'bout
Check it out: http://www.artlebedev.com/everything/optimus/keyb_002.jpg
squeezee said:The G15 does feel somewhat greasy, even when there doesn't appear to be anything on it or your hands. As well the keys are painted black unfortunately the black paint is on the key surface. While it may be cheaper for them to do it this way it makes for an inferior product. For those of you who haven't witnessed the awesomeness of the G15 yet, here is a pic.
In my case the wear wasn't apparent until after 2 months, its about 3 months now and the 'S' key is pretty messed up, the 'W' , 'E' and 'I' keys are starting to wear as well. There are also some small spots where you can see the backlight leaking through on other keys across the keyboard.
Next step is to call Logitech and see if they'll refund the purchase price or send me a different model keyboard. I doubt i'll have any luck with that tho.
LOCO LAPTOP said:You can RMA that keyboard, they will give u a new one for free and you dont have to ship yours back. i did it before![]()
Met-AL said:Vaporware?
