Logitech G11- No Del no Bios?
Justin Cider
I'm having an issue with my keyboard,when I try to get into the bios it will not recognize when I push the Del button but if I use and old ps/2 keyboard it works.I have enabled usb legacy support last time I was in there.I'm I going insane and missing something simple?or is there an hardware issue I'm not seeing.I know it worked before.The motherboard is an A-bit IP35 pro if that helps.If some one could help me out it would be appreciated.
USB legacy support is to detect USB flash drives and USB hard drives during POST. Under integrated peripherals look for a setting called USB Keyboard support, it will say something about using a USB keyboard under MS-DOS. Enable that and see if you can get into the bios with your USB keyboard.
