Logitech dinovo RF vs BT
ltspock
Can I get a comparison between these two units? I currently have two BT units and they seem to work well, and will be purchasing a third. I am interested in whether or not the RF version works just as well? Thanks,
while I dont have this exact set I do have a wireless mouse/keyboard from Logitech that use RF. My mouse is the MX1000 and it works just fine as does the keyboard. Im not 100% sure on this but usually BT is more expensive than the same unit that uses RF and unless you are using something that has BT in it you still need to install a reciever of some sort. In all honesty its up to you. I have used BT stuff before and IMO it doesnt really work any better than RF for a kb/mouse combo.
Only reason to pay extra for BT is if your other stuff is BT too. Or maybe you want one receiver for everything. With RF you have that annoying stub reciever thing (it's really annoying on a laptop).
What is the range of RF? I noticed that their updated BT Keyboard has BT 2.0 including a 60ft range. If RF has that range, then I will stick with RF and save the dough.
Thanks,
I havent used my RF kb from 60ft but I have used it from somewhere around 10-15 ft and it worked just fine. If you are going to use it with something like an HTPC in a room RF will work just the same if you ask me. Like 444 said BT is nice if all your devices are BT then you just have one reciever for everything where you do need that big ass RF box for the other types. With my keyboard anyway they arent line of site, do my reciever just sits on the floor behind my PC so I dont even see it. BT is really nice on laptops though as more and more have it installed in them from the factory.
I have an MX900 BT mouse and keyboard and an MX1000 RF Mouse and both seem pretty much the same.
I played BF2 on both machines with both mice and no lag issues with either.
