Logitech cursor freezes but mouse still workin
do you have any sort of logitech mouse drivers installed? I've had all sorts of problems with mice when I tried to use anything besides windows drivers. counterintuitive, I know.
the batteries are fine im sure as they are rechargeable and fully charged i also tried using regular duracells still problem occurs. What's strange is this problem is totaly random i can never duplicate it. Im using the Keyboard driver which is logitech could that be causing problems with my mouse, i seriously do not want to change it as my keyboard has many hotkeys i would love to use especially some which i assigned specific keys to. (such as webcam opens up winamp)
If there is a way to set these extra buttons w/o the proper driver please tell me
srry to bump but i also have added a screenshot of this innoying problem
my.php
notice the start button glowing (the mouse is really there) but notice where the cursor is (in the middle of the screen)
This is really hard to navigate and i have found no way of fixing it, only a reboot seems to calm it down.
Ok, i just installed another cordless mouse and i conclude it is not the mouse fault but it must be my computer as the same problem has occured any insight.?
Honestly, cordless mice are almost never worth their trouble. get a $10 USB mouse and see what happens.
For what it's worth, I have a Logitech keyboard and trackball. I have loaded the latest Logitech software for both, and have had no issues. I too like to use the extra keyboard hotkeys. I wish I could help you with your cursor problem, but I don't have any suggestions at the moment.
You could try running the system file checker or booting from your CD and doing a windows repair? Might save you from a reinstall..
