Hey
I have a nice set of the Z-5500's from logitech, they are connected to my X-Fi (extreme music) via the 3 analog stereo plugs.
The head unit (control pod) for the 5500's has 2 jacks on the side, one of them is heaset, and the one below seems to be "line in".
Is there any way I can use this "line in" located on the control pod to use my mic via control pod?
curretnly the only way I can get it working is by directly connecting the MIC to the X-Fi card in the 4th (multi purpose port) while pluging the headset to the control pod, which makes it akward. (one cable to xfi, one to pod)
Anyway I can get it working by using the "line in" located in the 5500's control pod, so that both plugs are in the control pod?
thanks
thanks
