Logitec MX1000 troubles
Kasher_Khan
So I got a logitech MX1000 mouse for christmas. This is my first cordless mouse so I am not sure if it is me or the mouse that has the problem here.
Anyways... I plugged in the mouse, installed the software. But!... the mouse is some how performing really really jerky. It's like when I move it around on any settings, it keeps getting stuck. e.g I could move my wrist all the way from the left of my mouse pad to the other end and the cursor would have barely moved a few inches on the screen.
I have a native of 1680 by 1050 res on my desktop so I was hoping the added tracking ability of this mouse would be good but it seems this is a problem with the RF signal. I moved my charger around to see if that was the issue but no success so far!
The gamming performance is pretty much as bad... Please any of you that have this mouse... HELP!!!
I have owned this mouse since its release, it owns. Once you get this problem figured out i know you will love it :D
Anyways, How far away is your base from the mouse? Mine is kept about 1-2 feet away, i know it can pick up alot farther away, but that seems to be perfect for me.
Also try switching between the USB and PS/2 ports, i know there was a bug with some models of the MX1000 that would be jerky with the USB port being used (ive heard Logitech will replace the base for those).
I had to get rid of this mouse for similar problems, plus the mouse is so HEAVY. I like my mx518 much better :)
c1001 said:
what surface are you using this mouse on?
Belkin mouse pad... Black color
I have a multi moniter setup. The mouse handles better on 1152 by 864 then it does on 1680 by 1050?
Does this mean I am not used to the extra sensitivity yet or what?
The jerkiness and freezing has since disappeared and I don't recall doing anything differently? ....
