Lockups with new ram Help!
R
ring.of.steel
Guest
Hi,
i have just installed some coarsir XMS2 2048 2X1GB ddr667 ram last night. i change fsb to 275 and i get lockups in windows, change fsb to 250 and i get lockups.
my bios settings are
fsb 250mhz
multi 10x
cpu 1.4v
ddr2 1.95v
ddr2 533 divider
5 5 5 15 timings
2t command rate
i have loosend everything up to try stop the lockups. works fine at stock.
(was running the x2 3800 at 3ghz with corsair value 2x256 at ddr400 speeds)
hi,
im not used to DDR2 dividers, is the 1:1 equivalent running the ram with the 667 divider?
cheers
The divider at 1:1 would bring the memory in sync with the FSB and CPU, if your FSB is 250MHz and you are using the 1:1 divider, then your memory would be running 500MHz, if you set your FSB to 333MHz, then with the 1:1 divider the memory would run at the (rated) speed of 666/667 MHz.
Hopes this helps a bit...
bit confused here...
my motherboard has options for
DDR400
DDR533
DDR667
DDR800
so i should select DDR667 for the 1:1 ratio?
i have just moved from a dfi ultra d the other week and ddr2 is confusing lol
I'd say start with the lowest speed you can and then run memtest, that's what I would do anyways
am using ddr667 but just randomly restarted.
no memtest errors since this morning...
ddr2 voltage is now at 2.0v
is there anything else it could be?
