Lockups in game menus?
Esso
Hey All,
I need your [H]elp troubleshooting an issue that I have had since I built this system back in November '09. I'm guessing it is a problem with the video card, but I am not quite sure where the best starting point is to begin troubleshooting. Since driver & BIOS updates have not seemed to help or hinder, I figured that I should probably get my ducks in a row so that I can get my gear RMA'd before warranties expire (if necessary).
So here's the deal:
My system will sometimes lockup while in game menus. Moreover, when loading a said game, things seem functional for anywhere between 2 to 15 seconds. At this point, the cursor gets jumpy and then stops moving completely. While this goes on, num lock can't be toggled, the system won't respond to alt-tabs, ctrl-alt-dels, or anything else other than a hard reset. Background music of the game continues for quite a while before it completely craps out, probably 5-7 minutes, no short sound loops though.
The issue does not seem to be consistent, but happens often enough to frustrate me... let's say one in every 6 launches. This can happen after a fresh reboot, but seems like rare occurrence.
While in-game or even outside of games completely (desktop or other apps), I have never had a lock up. Everything is running @ stock clocks, except for one minor change. In order to prevent artifacting/freezing while in and out of games, I have raised the 2D clocks on both GPUs as noted below. Also all motherboard/gpu temps check in as normal.
Specs:
Win7 x64
Core i7 860 (stock clocks atm)
Asus P7P557D-E Prem. (bios v0711, I see there is a new rev from 6 days ago... i'll try it but I'm not hopeful)
G.SKILL 2x2GB F3-16000CL9D-4GBRH PC3-16000 (stock timings, switched to XMP profile lately)
MSI Radeon 5970 (2D profile set to 400/900 on both GPUs) [10.3b Catalysts]
SB x-fi xtreme gamer
Thermaltake Toughpower 1200W
The RAM checks out OK from memtest86 & a few other apps I've tried.
I was thinking of popping out the sound card on a whim (X-fi's seem to have issues with Win7 x64) or possibly just replace the GPU if I can find a nice enough friend willing to swap parts.
Any suggestions on a good starting point?
It seems like GPU-Z can't log both GPUs at the same time and also does not play nice if you try to run two separate instances simultaneously...
I am guessing that raising the 2D clocks higher will not really help either... *shrugs*
Oh and for what it's worth, off the top of my head here are the games I've seen lock, but it's probably all games:
-BF BC2
-COD MW2
-L4D2
-Torchlight
-Ghostbusters
-SC2 beta
Don't have a specific answer but I like the sound of pulling the X-fi for troubleshooting, if that isn't the cause I'd try underclocking the 5970, and after that try it with Catalyst AI turned off to disable the 2nd GPU Crossfire mode.
It could be your keyboard or mouse going bad.
I've had this problem in the past with Razer products, switched that junk out and it was perfect.
Try removing the sound card + Drivers reseat the ram and gpu and make shure a setting in ur bios is not causing the problem or ur cpu overheating
You didn't mention it, but do you hear the USB reconnecting and keyboard/mouse flickering when this happens? I had an odd issue mainly in game menus with lots of animation in the background where my mouse would drop offline and reconnect over and over again as I would move it. Had to plug my mouse in directly into my computer as opposed to my monitor's built-in USB hub. I'm thinking it was a power issue when the video cards would be pushing too much data (especially in 2D modes) to the monitor while also keeping the built-in hub powered. That's a guess anyways. Hasn't happened anymore since being plugged directly into the computer.
Thanks for the responses everyone... Looks like I will have my hands full over the weekend.
I don't have any razor gear, but I will try swapping the kb/m as well the other suggestions here.
The keyboard is nothing special (ps/2 generic) and the mouse is a CM Sentinal Storm, it's sorta 'meh' anyway. I have not heard any plug & play sounds or noticed any flickering on the devices (or GUIs) when this happens and all inputs are directly connected to the motherboard. The psu is attached to a ups, which gets angry when I run the FurMark xtreme stress test, but everything still runs normal during that test, say if you wanted to browse the 'net while that was going on. Oh by 'angry' I just mean the ups fan kicks in and the battery lights flash in tandem suggesting that I wouldn't get 2 minutes of uptime from the battery. So by that I am guessing that the PSU is pushing out power without any problems.
One thing that tends to happen only in game menus is that the video card can generate many hundreds or even thousands of FPS. This is ordinarily a cause of coil whine. What happens if you force Vsync to always be on?
All, sorry to resurrect this old thread. In the event that some else ever comes across a similar issue, this did turn about to be a problem with the card itself.
I did test this card on a few different motherboards (1366 & 1156 socket Asus boards and a 775 Gigabyte) the problems stuck through and actually seemed worse.
After a lot of pain, I was finally able to convince MSI to allow an RMA and the replacement card is working without problem.
The good: MSI sent me a brand new card, not refurb'd - This also game with the original peripherals, like mini display port to display port, that may come in handy later on down the road.
The bad: MSI's support team is a joke; I will seriously reconsider buying any product from them again for this reason.
