Hey everyone.
Been a longtime ATi fan. Recently upgraded my ancient Radeon 7200 class graphics card (R100 based!
). She served me well..
Anyway, I bought a Sapphire x700 AGP card.
Installed the card with no trouble and updated the unified ATi drivers to the latest versions.
This is where my problems began. Firstly I would get crashes as soon as ANY 3d graphics started up (including the graphics in the Catalyst control centre). I fiddled around and finally determined that my mobo-graphicscard combo didn't like AGP x8. Dropping this down to x4 made that initial problem go away.
I still get random lockups when 3d graphics are running. They are by no means frequent, but it's mighty annoying.
I've also noticed that the lockups DO occur more frequently if I have any form on AA on. Rollercoaster Tycoon 3 for example runs without too much trouble with AA off, but when you enable it, you can bet your life it'll crash at some random interval within the next five minutes.
The crashes usually consist of the picture freezing - sometimes the mouse still moves, sometimes not - then after a few seconds the machine resets but will not boot again.
On occasion, the crashes have been 'recovered' by ATi's VPU recover thingy, but that doesn't happen often.
Have any of you guys heard of this before? Is it a power issue? I've tried disconnecting the power to everything I don't need and it still occurs.
I've tried with Fast Writes OFF in the BIOS.
I've tried with the case open and closed. It's not a heat issue.
I've tried with the integrated LAN, SATA, Firewire - you name it - off.
I've tried pretty much everything.
So I'm at a loss.
Specs, then:
Abit NF7-S v2.0
AthlonXP 2300M
Seagate Barracuda 40 gig - IDE
Seagate Barracuda 200 gig - SATA
Antex Sonata case, with its standard 380w PSU
Any help would be glady appreciated!
Thanks,
paul
So I'm at a loss.
Specs, then:
Abit NF7-S v2.0
AthlonXP 2300M
Thanks,
paul
