Local AI for document parsing, etc
Hi all,
I don't know where to get started but I want to investigate running localized AI for parsing through my documents such as a PDF Library having hundreds of GBs of books and also my own personal writings and notes. I'm an author so I have a lot of material that I've written over the years that I want to analyze.
I don't need instant answers so speed is not a key point now. Can you tell me what to search on Google to find these answers? Not a computer programmer (hobbyist level, have done some work in python years ago) but able to work in Linux and command line. Just looking for guidance to some material and also terminology. Thanks in advance
"docmind" may work for that.
My memory says that Ollama has a library entrry to parse PDFs, but I can't find it right now.
Get ollama setup and find a model to do what you want. I've just used language models though, nothing for parsing imagines. Anticipate atleast a moderate hardware demand.
I asked Ollama in my best English accent to find me a PDF File. Why are the cops here?
There's also RAG (https://dev.to/the_aayush_mishra/setting-up-rag-locally-with-ollama-a-beginner-friendly-guide-428m).
What is RAG?​
Retrieval-Augmented Generation (RAG) is a technique that enhances large language models (LLMs) by enabling them to access and utilize external knowledge sources during response generation.
Think of it like this:
Instead of relying only on what the LLM was trained on, RAG lets it search a knowledge base (like your PDFs, notes, or datastores) and combine that retrieved information with its reasoning capabilities.
Quick example:
Imagine you need to understand your company's 120-page policy manual. Instead of manually searching through it, you can just ask: "What's the travel reimbursement policy?" A RAG system will fetch the relevant paragraph from the PDF, and the LLM will generate a clear answer based on that specific content.
I've yet to set it up locally, though. My dedicated AI box is almost done. :) My main PC does mostly image generation, LLM stuff (n8n uses it to write things, summarize articles, etc. to send me).
