Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is there some software out there that will load balance 2 nics? I want to get another DSL line into my office and load balance them so I can use the full bandwith of both DSL connections from a single program.
Unfortunately it's not that simple. At minimum you will need a dual WAN broadband router (I say minimum because they are the easiest to set up), from there you could do it with various other solutions from Cisco, etc. I have never tried this with any form of BSD, but this might be possible as well.
