Living a Nightmare, Please Help!
Tooterfish
The Story (skip if you dont care):
A couple weeks ago, my swiftech pump failed. My computer overheated, and shut down. I took out the pump (running redundant loop) and left the good one, called Gabe at swiftech (he told me its the EK waterblock's fault), and pressed on. While I was in there, I changed some tubing, and accidentally spilled some left over water from my cpu block onto one of my three gtx580's that are also being water cooled.
After getting everything peiced back together, I started my computer up and noticed the card in the first lane stopped working. BIOS wasn't detecting it, and it was seated and powered fine. I tried the card in other lanes, put working cards into the first lane, and everything pointed to the card being toast. The bad card wouldn't work in the other lanes, and the good cards worked fine in the first etc.
So I replaced the card.. All 700 dollars of it, along with a new swiftech pump to run a redundant loop. The nightmare really begins here...
Everything but the new swiftech pump was working fine, the new pump I got was giving me problems, not really a big deal because the other pump ran fine. My sata drives fell out of raid and were acting weird, so I reformated. I discovered my poorly made fan controller's molex was bad and had to replace it to keep my fans running, calcium had built up snowballs of white beads of death inside my computer which had to be flushed. I guess this is from leaving it exposed for a couple weeks without running. Just minor problems, really, the new GPU was working great and I knew I would get everything situated eventually.
After windows installed on my new raid, I put in all the drivers, fixed up all the little things and peiced the case back together. I played a bit of Metro2033 last night to stress out the computer a bit, then played some Xbox while I downloaded some games off steam. I finished the night up with the rest of the windows updates and powered it down.
Now it gets depressing...
This morning I wake up, and the gpu in the first lane isn't working. BIOS doesn't detect it and, like before, I troubleshooted all morning to find it to be toast. That's $1500 in GPU's gone in less than 3 weeks, something is seriously wrong here.
Quick Version w/ specs!
I have 3 GTX580's in 3-way SLI on an Asus Maximus IV board. I am watercooling the cards, and a couple weeks ago I got a leak. The leak got my video card in my first slot wet. After drying it the card didn't work anymore. I recently replaced it with a new one, got everything up and running, reformated and all was good in the world. I woke up today to install some games and the new card in the first slot doesn't work, BIOS doesn't even detect it. I'm angry, frustrated, confused, and I jarateed away so much money, any help would be appreciated!
What I've done so far:
I did take out the cards, trying them one by one. The 2 good cards work in the first lane, and the bad one doesn't work in any. This is exactly what I did the first time before I replaced the card with same results, leading me to believe it was a bad card.
I am running the latest release of BIOS firmware for my board. I made sure of that.
2600k
Maximus IV
3x GTX580 Hydrocopper 2 3GB
16GB Mushkin Memory
2x 120GB Vertex 3 in Raid 0
Asus Xonar Essence
1200 Watt Corsair PSU
Windows 7 Home Premium
It seems like some of the coolant that was spilt onto the videocard may have gotten into the pci-e slot and could have caused corrosion in the slot, causing an intermittent connection. Also, this could have damaged a component on the motherboard. just to note: i recently blew out the dust in my computer. It sits in my garage shop, so it does get rather dusty. When i restarted the machine, it wouldn't post. I then took the videocard out and blew out the pci-e slot and reinstalled the card and it booted right up. just that small amount of dust or lint that apparently got into the pci-e slot when i blew the computer case out caused this issue.
