I have Microsoft Windows Live OneCare loaded on all three of my computers at home. The software works great, but I'm having one issue. I can't ping or map drives to any of my machines. The are all on the same subnet, and if I disable the Firewall (by lowering the slider to the bottom), I can connect to any machine from any machine as normal. With the settings slider set to auto, I can't even ping the machines. I currently have the advanced settings set to allow file and print sharing from my subnet, which I figured would have solved this problem. Are there other things I should be enabling, under ports or so?
