Little questions
Leila87
Hello all.
I am trying to build a new pc with this mb, cpu and ram:
ASUS P5W DH DELUXE
Core 2 Duo E6600
OCZ 2GB 667 (2X1024) OCZ26672048VPDC-K CL 5-5-5-15
If i want to archive 3.0ghz and have a ratio of 1:1 tell me if this is correct:
FSB 333*9 = 2997
DDR frequency 667
And if i dont want yet to do any overclock, with this ram can i put this?
FSB 266*9 = 2394
DDR frequency 533
Excuse me :confused: , i am really confused just want to be sure...
Thanks in advance.
Leila87 said:
Hello all.
ASUS P5W DH DELUXE
Core 2 Duo E6600
FSB 333*9 = 2997
DDR frequency 667
FSB 266*9 = 2394
DDR frequency 533
Thanks in advance.
Bingo.
Seems like you aren't confused at all :)
sardonic.n7 said:
Bingo.
Thanks for your reply... so what is the point on buying ddr2 800? will i get better performance if it is not 1:1 and fsb is lower?
If you choose to utilize the DDR800 bandwidth (you'll normally need to enable this in the BIOS yourself) you'll get a bit better performance.
Buying good ram allows you to overclock ALOT ;).
