I hadn't realized you were using existing heatpipes to cool your stuff (i don't know why i lived in fairytale land on this one), I thought you were making your heatpipes. and that being the case the next img upload will seem sorta silly but whatevs.
I had seen you said that maybe you'd upgrade to an i5 to play a game or two and thought, you could buy a low profile card and do this. there is a 5570 that'd fit mostly well...not that it's a gaming card but if my son can play COD games on a 4350 then a 5570 would be better.
and then i thought it'd probably spread the heat better if the pipes ran the length of the HS
AGAIN. I somehow thought you made your own heat pipes, so these are all fairytale thoughts unless you can get some longer pipes. I think that your growing heat issue would be canceled out if the pipes ran a longer length on the side heat sinks. Longer dissipation of heat and such
