So i have been using this half finished silent HTPC project for quite a while now, and decided to upgrade the motherboard. (couldnt resist the asus p8z77 -i deluxe)
anyways my rather ugly but well working cooler for the i3 no longer fit,
Imgur album of old and new
and now its an i5 ivy i thought it ought to have a few more heatpipes.
I have a small cnc router, which is really meant for wood and plastic, but i thought i would give it a try with aluminum
(picture of it with a different spindle, it had a Bosch colt trim router to do this. (1/8 milling bit)
with 10000 RPM and slow feed (20 IPM) it cuts the aluminum accurately, but the finish on the sides is not that great, maybe i am using the wrong kind of bit, speed could be wrong, these things take a while to get right for a particular machine.
Here are the pieces done. the base is 9/16 solid aluminum and the top plate is 3/8ths. the base rests directly on the CPU.
It is designed to only occupy the "mounting bracket exclusion area" or whatever intel calls it, anyways it does not hit anything.
I need to thread the bolt holes and form the ends of the heatpipes to fit the holes for them, but you can see how it will fit together. (imagine it with all 5 heatpipes)
Once again the heatpipes came from one of those rather useless zalman hard drive coolers.(version 2 this time) they are good for getting heatpipes from. I did test the heatpipes to make sure they were not just empty copper pipes put there for show, they will get too hot to touch very quick if you put one end in boiling water!
if the chipset gets too hot:
I may add a couple more heatpipes, or even machine a replacement block for that chipset heatsink which connects directly to the left external heatsink. the last motherboard had no problems like that though i left it running for weeks on end, (sometimes encoding if something would not play, but mainly it just plays movies and older/lightweight games
