Ok I recently bought the Hauppauge Wintv-Go card that was posted in Hotdeals.
http://www.hardforum.com/showthread.php?t=835374&highlight=dscaler I bought it so I could capture some home video's to put on DVD
I'm using Dscaler to do the capture. My problem is the Capture resolution. I think I figured out where I went wrong. (While driving to work this morning no less.) I have it set to 1.33 which I got to thinking about is Widescreen. (Of course I noticed the end result when capturing, but at the time was thinking 1.33 was what I needed it set to.) So what do I need it set it to when capturing normal video?
Thanks a bunch.
Thanks a bunch.
