ok. a little while ago(bout a month and a half) i got my athlon 64 setup
i never ran it on air. went right to watercooling. im using a hydor L30 II(2) pump with a swiftech MCW5000 waterblock. im using a single 80 MM radiator with 3/8"ID tubing and a single 5-1/4" bayres resevoir
my temps are 39*C-40*C at IDLE on my 2800+ with it overclocked to 2.43ghz at 1.55 vCore.
load temps are: 40*c-42*c
should my idle temps be cause for concearn? if i got a cheap generic (i have no money to spend now) single 120MM radiator and mounted it at the bottom of my case would it help?
