Little computer stand or shelf
So right now my ITX case is where my large tower use to be, but it's like half the height so I have to prop it up on the box it came in so I can easily use USB ports or push the power button. Not very flattering. I'm looking to find some sort of stand or shelf that I can use to put it in instead. I also use to put my PS3 on top of the heavy tower case, but I don't want to do that on a light aluminum ITX. The stand or shelf should be minimal and narrow, as there is a few inches to the left and then there's the room door. Any suggestions? Here's the case if it matters (I cut the annoying blue light). http://www.amazon.com/LIAN-PC-Q08B-...F8&qid=1405830281&sr=8-1&keywords=lian+li+q08
Look up 'microwave shelves'/'microwave brackets'. They're generally sturdier than normal general-use shelves.
I've hang my PCQ-08 under my desk. Feels like the perfect solution for me.
But it won't help in the PS3 situation.
