Literally about to start building my pc.
K3Fallout
I'm just making this thread since this is the first time ever that I will build a pc and will put questions up here if I run into anything. I'll try to get pictures up but heres my parts:
Mobo- Intel Bad Axe 2
RAM- G.Skill 2gb HZ
GPU- BFG 7600GT
CPU- Intel E6600
Heatsink-Thermalright Ultra 120 Extreme. Will ghetto mod it with two fans using a push/pull config.
HDD-Seagate 160gb SATA
DVD Burner- Samsung SATA 18x burner
Case- Antec P182 with a bunch of Yate Loons.
Woot! Let's hope I don't screw up. But here's one question that remains unanswered.
If I connect my heatsink fans to the mobo, can I control the fan speed? This question would probably fit in with people who actually have this mobo but yeah. This mobo isn't listed as being supported by Speedfan.
Well, here goes nothing. Let's hope I don't screw up or run into anything dead parts. For Spaaaartaaaaaaaaaaa
I was hoping for a lot more responses but ok. Anyhow, everything seems to be good but I've run into a snag. The damned thing won't detect my hard drive. I checked the bios and everything seemed in order. the auto detect bit was enabled, it was set to IDE. I reconnected the cables several times. Is my hard drive possibly dead?
Does the hard drive spin up?
Does the bios recognise the drive? - there should be a menu showing what drives are connected
Yeah the BIOS recognizes it as well as my dvd burner. I'll go see if it spins.
Here are some horrible quality pictures:
First I see my video card:
Then this mess:
you have a sata hd, not ide...do you have it hooked up with the sata power cable and the little sata connector hooked to sata port 1?
Yeah I do. I do know that this is an SATA hdd, the BIOS set it as IDE as the only other options are AHCI or RAID.
Yeah I believe IDE is what it should be set to, unless you want to go RAID, which obviously you don't.
When do those messages that you posted images of show up? The first one is normal, it just shows the video card info or something, I get that too, but what about those 2 other shots? What happens when you run the setup of the OS you want to install? Does the OS detect the hard drive?
Also sometimes connecting your HD to a different connector makes a difference, like on my mobo.
Those shots happen after showing the video card. I'm going to try to load the OS and see if anything happens. I've tried relocating to different slots to no avail. I'm not giving up yet. Hard to believe I started building at 12pm noon and now its 5:15. I'm not going to let this stupid problem hold me back.
One time I bought a 200 GB HDD and tried to install XP and Linux dual boot. It was my first linux install and I tried to install Gentoo. Big mistake. Needless to say, I started at 10:00 AM Saturday finally ended up right where I started at 10:00 PM, the next day. Yes, that's 36 straight hours. No, I'm not joking.
You still have a few hours left to go before giving up young grasshopper.....
Ok um.. I just loaded up the Windows CD and it seems to work now...? If this really works out, I'm going to kick myself for not trying this in the first place and wasting two extra hours.
