LiteCoin Wallet Questions
thefordmccord
OK, I feel like a tard because I can't seem to find a straight forward answer on how to make this work.
I am mining litecoins on a few random nvidia cards using cudaminer. I am set up with the pool wemineltc.com. I have the litecoin wallet software running on my computer.
My question is, how to I get the coins that I mine moved into my local wallet? For some reason, it is not making any sense to me and I need someone to hold this old man's hand through the process.
Thanks for any help!!
You must specify a "payout address" in your pool.
Then set an auto-payout amount. Minimum auto-payout at wemineltc is 5 LTC.
In your wallet, click on "receive" and it shows you an address. You can make a new address if you like, each wallet can have multiple "receive addresses". Copy that wallet ID and paste it into your account info at wemineltc for the payout address.
Set the auto payout to 5 and it will auto payout to the wallet address you specify.
Awesome! Thank you very much for the help. I think I have it under control now.
