List keeps building... Finally asking for [h]elp! Assorted Problems.
DJS2
Hey all, I need some major help. First off, this is my first custom built system that i put together a little over a year ago. If you guys could try to look at some of the problems im having I would really appreciate it.
  1. When I press the power button to startup my computer, the top/bottom led will light up and the fans will turn on for 1-2 seconds. After this the computer will "die." The only way my computer will start is if i press the startup button 2-3 times very fast one after the other, then the computer will properly power up.
  2. Sometimes after my computer boots, i get a CMOS/runtime error. After this my clock resets to 1/01/03. I have put in a brand new battery (Im sure its the correct one) and i still get this error occasionally.
  3. After startup, at the Windows XP login screen, after I enter my password, it gets stuck as it tries to log me in. After about 30 seconds at the login screen, I am shown a black screen (my desktop wallpaper) indefinitely. The only way i can get out of the blank screen is by opening the Task Manager and ending the only task that is running which is explorer.exe. After ending explorer.exe i am taken back to the login in screen. This happens occasionally.
  4. Very rarely I get missing file errors and such. I also have memory leaks whenever i shut down the computer. (I have Visual Studio)
I have scanned my computer with mcafee for viruses and nothing came up. Once my computer is on, it usually runs pretty well. Lately though, especially when multi-tasking, it stalls pretty quickly.
My Computer Specs:
Processor: AMD Athlon 64 3500+
Videocard: Leadtek GeForce 6800GT - (RMA'd first one, 4 months old)
PSU: Antec 500watt Smartpower 2.0 - (RMA'd first one, 4 months old)
Mainboard: DFI Infinity nf4 SLI
Memory: CORSAIR XMS 1GB DDR400(PC 3200)
Hard Drive 1: WD 10k Raptor Drive - (primary drive with windows)
Hard Drive 2: Seagate 250gb Sata Drive
Water Cooling: TDX Waterblock, D5 pump, X-Flow Stealth GTS 240 Black Ice Radiator.
I have had this problem before. (hence why i RMA'd the PSU and Video card). It fixed the problem but i do not want to keep having to RMA my hardware every 4 months... Any help/suggestions would be very helpful.
Thanks,
Daniel
1. get a higher quality psu and I have no idea about the others.
Yes, soon i plan to get a new mobo, psu, and dual core processor. More Help/Opinions would be greatly appreciated :)
Could i be having certain problems due to Windows XP being on my raptor drive? Are they more prone to mess up during installation and such?
I doubt it. I've never had any problems, at least. :p
It could be you have a flaky connection somewhere, double-check all cables in the case?
Also, have you tried reformatting? I was having problems that I would have sworn were hardware related, but I reformatted a couple days ago and no problems so far. *knock on wood* But your problems are a little deeper than mine were.
It seems like a flaky board. I'd run memtest overnight. If it passes, I'd run some HDD diagnostic tools. If those don't pass, or even if they do, I'd replace the ide/sata cables. Then I'd reformat and do a clean install of windows. Then I'd get updated drivers for the motherboard.
Well, if im going to reformat i would rather do it after i know that any new hardware that i buy is installed and working first. Than if my problems are gone than i save the time of reformating. (I know you can look at it the other way around, and maybe save all that money on hardware if the reformat fixes it, but hey, im a sucker for new computer parts :p )
I was thinking my mobo was dieing or something as well.. I am currently running memtest on the comp (im on a different one). It is at 3 hours with 8 passes and 0 errors. nvidia nforce 4 chipset, with ECC DISABLED. Is it supposed to be disabled? Also how long should i wait? 12-24 hours almost seems impossible for me. :)
Thanks very much.
You have 1GB, so overnight (about 8 hours) should do it. ECC is a function of the RAM, usually, and I doubt the ram you have has ECC. So yes, its fine if its disabled.
I ran memtest and it returned 0 errors. Any other suggestions?
Hey, if you got the money, go for it. :D
Whats a good HDD diagnostic tool? I want to reformat and reinstall windows but i think that having trouble powering the computer on would still happen even after a format.
If you can get into windows, HDTune can read the SMART data for you. If not, go to the drive manufacturers site and DL whichever diagnostic tool they offer in their support/downloads section.
Thanks.
I downloaded HDTune and it came up with 0 errors after testing both hard drives.
