Carnival Forces
- Feb 9, 2003
Thing is, I don't recall hearing of any liquid metals that aren't. EDIT: Oops, stand corrected. The link to this particular cooling actually says the liquid metal they use is non-toxic.pxc said:It's a toxic heavy metal. I can't see this going retail.
It will have fan(s). A small passive radiator won't exchange heat fast enough, especially on an over 75W chip like the x850XT. IMO, they will go with a blower design like the ATI Silencer. You can already see the double-wide slot bracket has exhaust holes.Hate_Bot said:heres a pic (the final version wont have fans)
http://www.theinquirer.net/?article=23331
Passive cooling=Quieter=Better
The company will show off some early prototypes of the card at E3 and at this time liquid metal cooling will have some fans on while a final design might lose the fans. It can work completely fan ess and can cool the high end fastest and latest greatest cards.
can't be wrong if you cover all the bases....
Just for the record, the prototype card still has fans while the final design will lose them.
Yeah, the card is going to run at 53F.Some early testing showed that prototype cooled Radeon X850XT PE card to just 12 Celsius.
The patent for this (by Nanocoolers, Inc.) uses a Gallium/Indium alloy as I mentioned above. If it leaks (heavy welds at the tube junctions should prevent it), it is definitely toxic.Nazo said:Thing is, I don't recall hearing of any liquid metals that aren't. EDIT: Oops, stand corrected. The link to this particular cooling actually says the liquid metal they use is non-toxic.
Rofl, seriously? I call THAT toxic... After all, I tend to breath air.Carnival Forces said:so it becomes toxic on contact with air![]()
heh, or as pxc said, some good b.s. potential. If a passive heatsink can be cooler than ambient temperatures, then they should make freezers that don't require power.Gr@ftoon said:12 C temps are pretty good, better than water cooling, now if it cooled the gpu and ram at 12 C without the fans, thats some good OC potential.![]()
nonono, that's my questionNazo said:Rofl, seriously? I call THAT toxic... After all, I tend to breath air.
*grumbles* Bloody marketing hype...
Carnival Forces said:what i want to know is, why isn't that out on my CPU??
Chix4mat said:If they say it's non-toxic, and it ends up being toxic.. I think both companies could risk getting shut down. Not sure if they are going to risk that.
Sounds like a cool new idea though.. 12ºC unlikely, even idle, but if it's better than water cooling, I'm all for seeing the temps.
Nazo said:But, the thermostat companies don't say "completely non-toxic" either. If it's toxic, the user still has a right to know. Hopefully it will never once even matter, but, it's still best to know, just in case.
How toxic is it if it is though? In the case of the mercury, it's only toxic if you ingest it (and I suppose get it in a cut or something.) I've seen millions of pictures in encyclopedias and such where it shows someone holding mercury in their hand without gloves or anything, so I suspect it's not immediately hazardous if it is. (Then again, Isopropyl is put on cuts and everything, but, enough -- and it takes a lot -- of that even just to uncut skin is poison.)
