Justintoxicated
- Apr 10, 2002
Hi Guys I have never done a liquid cooled computer before and my PC just bit the dust from some bad OCZ PC3200 C2 1 gig sticks.
So I'm starting over.
I'm going to RMA the memory, in the meantime I need to get into liquid.
I want a dual core AMD of course, and will likely need a new video card since AGP is not supported anymore. Bye bye 9800 pro
For $500 I need
Case
Radiator Preferably 2x120mm
Rez
Block for CPU
Tubing etc.
Recomend me some stuff!
I was looking at areocool masstige, CM Stacker (not sure which version), or Lian Li 2000b.
Not sure which will be the easiest to cram all my stuff into, nothing seems like it is exactly what I am looking for...
I want to mount Radiators internal if possible but side or top or rear mounted is fine too so long as it is easy.
I do NOT have any special tools, just a dremel, but I MIGHT be able to find someone to cut me some perfect circles.
Can I do a worthwhile liquid setup for this price and are there any good Links to show how to assemble an entire system?
Thanks.
For $500 I need
Case
Rez
Block for CPU
Tubing etc.
Thanks.
