liquid cooling & ambient temp
See-Fu
comparing liquid cooling to air cooling. which one would heat up a room more or would it be the same?
The same, the source is still dumping the same amount of heat. These are merely two different methods of dissipating that heat.
edit: We could probably say water produces more heat because you have more fans and a pump.
