BellaCroix
- Mar 25, 2004
Anyone ever use "Liquid Neon" CCTs? If a tube was hidden would the light given off still give the impression of water inside the case or is it just an effect when you look at the tube itself?
Not sure if I'm going to use them but I think I came up with a pretty slick place to hide one if it does give some kind of motion effect to the light inside the case. If not, it's probably not going to be worth it and I'll just use the usual UV tube or something. Ho-hum.
