LinX / IBT Settings (?)
liquidfluidity
When running these stress tests , are you guys just using the stock program settings or are you changing anything to max out the testing according to your hardware? What size problems are you using and how much ram are you allocating?
1. In LinX, problem size automatically gets larger with larger memory allocation - just adjust memory.
2. Stock settings are fine for a really quick test of stability. Eventually though, to make sure your entire system is rock solid, you're going to want to test with memory set to "All."
Thanks. I'll give it a try and see what i end up with. Just want to make sure things are rock solid before I start my over clock.
