Hello!
I am expecting my new A64 with 2GB RAM (Infineon DDR400) soon and want to upgrade to 4GB sometimes. Before that, following problem has to be solved:
There are rumours that memory "after" the first 3.5GB is used for PCI/AGP-Address-Space, so you can only use about 3.5GB RAM with current S939-Boards.
Is that true? Is there a way to use 4GB RAM?
What has to be set up in the kernel (I use Linux)?
Is there a difference between the boards (I'll get a Abit AV8)?
Thanks for every answer and link to further information!
